Text on a Path Flips Upside Down When Flip Horizontal is Used
Text on a path flips upside down (and horizontal as expected) when Flip Horizontal is used.
Steps to reproduce:
  1. Create some text
  2. Create an upside half circle using Draw Lines
  3. Select the text and the path
  4. Select Flip Horizontal
The following post might help.
https://forum.lightburnsoftware.com/t/applying-text-to-path-text-defaults-upside-down/3921
Or maybe considered using the recently released Bending Text feature to create the look you are after.
Thanks, Rick! The Bending Text was a good workaround (and was easier than the way I was doing it). I tried clicking on the link at the top and it didn’t work. I’m interested in reading the article if you get a chance to fix it.
