The 4 buttons at the bottom of the LB desktop allow or prohibit some functions “of the selected objects”, very nice and useful for some tasks. However, all objects, selected or not, are assigned the selected function, in all layers. This limits the otherwise fine function a lot.
A better and useful function would be that objects individually and independently of layer can be restricted or allowed in the functions intended for that purpose, such as move, size, rotate and shear, in the style of the existing lock function in the Shape Properties panel - but from a central position (bottom of the LB desktop) without a detour.
If it cannot be implemented, the subtitle in the 4 buttons should be corrected so that it is clear that the selected function applies to all objects in the current project, which is what they do.
It’s intended for environments where people want to be able to load a project and select things, but not accidentally change them (or just move them but not scale them). We had numerous requests for this functionality from shops that run pre-saved job files.
Making these functions only work on specific objects, or making layer-specific versions of these, would be extremely hard. You can, for example, put things from several layers in a group. If you were allowed to alter the group, but certain layers within it were locked in specific ways, the code to manage that would get ugly very quickly, and the experience wouldn’t be intuitive.
Thanks for the response. But I don’t agree with you.
It’s possible that I don’t see the possibilities in the 4 buttons as they work right now.
With slightly more complex design and construction work, which I usually always do in LightBurn, I can’t “protect” individual objects/shapes against rotation, scaling, moving… - without locking all objects in all layers. That is, I can’t use those buttons for anything because it prevents me from working with the rest of the project.
Right now I move “finished” construction elements to T1,T2 layer boxes with a big warning sign - “Do not touch!!”
In the new LB version I have the option to move these parts to a new project window and group the elements/shapes I want locked into smaller groups (but then they unfortunately can’t be moved anymore). However, I already see it as a progress and limited alternative to the problem I describe.
But being able to “protect” shapes individually for individual edits, in the project windows they belong to, would still be more elegant and a further step in making LB a better design tool. After all, this is where the biggest development opportunities for LB lie. But like everything else, it is a matter of priority, I understand that.
NB. If someone needs to protect an entire project, it would probably be better and clearer to make a single button with a padlock icon that closes one’s entire project.
