The laser doesn't turn off between figures $32???
Good afternoon, I have a problem with my 5W laser, it is mounted on a 3D printer, the Ender 3 S1, everything works fine, but when I cut or engrave something in the movement between pieces the laser does not turn off and leaves a line engraved on the material, I have seen that the $32 option must be enabled, the problem is that even though everything works fine, when I enter the console and enter $$ and it shows an unknown command and if I access the machine settings everything appears blank, I have it configured in GRBL, I leave the code that the console leaves me when engraving the first image.
Thanks in advance.
What does console show when it first connects?
Does the device come with or support a laser?
It appears to be it’s using a cnc mode that doesn’t turn the spindle off between moves… this is common, and is corrected by the $32 variable to enable laser mode in the controller.
When you attempt to read the machine settings, it advises you there was nothing returned, so it’s probably a different variation of firmware.
Agree with @Dskall you need to show the first connection in the console which will tell us what firmware you are running.
Maybe try Marlin device?
Good morning, what appears when you connect is this, it may also be $$ and it says unknown command.
Waiting for connection…
-9�Ye%�ok
ok
echo:Unknown command: “$I”
ok
Homing
echo:Unknown command: “$H”
ok
echo:Unknown command: “$$”
ok
Good morning.
It is actually a 3D printer, the Creality Ender 3 S1, but it is compatible with the 1.6W, 5W and 10W Creality lasers.
The problem is that I cannot access the console to change the variable $32 because the console does not respond and it does not give me the Firmware version either :frowning:
Thanks!
-9�Ye%�ok
ok
ok
Homing
ok
ok
Good morning.
It doesn’t connect directly to Marlin.
Thanks.
Ender 3S1 controller is based on a STM32 chip the last resort I can remember is creating a new Device based on Gerbil-STM or maybe GRBL-LPC and test.
And also check if they appears in Windows Device Manager or need a driver.
With Gerbil-STM it doesn’t connect.
With GRBL-LPC it doesn’t draw figures, it just makes a straight line and goes back home.
Thank you for your help :slight_smile:
Com5 is the port assigned in Windows Device Manager?
If correct, Windows assigns port Com5
COM 5
Good morning, can anyone help me? Does anyone know how to solve this problem?
Thanks!
I suggest you send a note to support, if it’s supported they can help you determine which control board it has and which device you need to use in the device setup.
If you don’t mind hanging around, maybe @gilaraujo can help you figure it out.
A few questions regarding Ender 3 S1 (not Pro):
  1. Did you have the Creality laser control board or the laser is directly connected to the printer?
  2. Did you update or is in the printer the firmware “Marlin2.0.8_Ender-3S1_HWv24S1_301_SWV3.1.9_Two_C_F401_FDM_LASER” or newer?
    Ender-3 S1 Software & Firmware Download - Creality 3D Printer
  3. Did you test first with “Creality_Print-v3.12.2.3188-win64-Release”
    At the end of this page:
    Ender-3 S1 Pro Software& Firmware Download - Creality 3D Printer
    and selecting:
    image.
    Output of the Creality Print software:
;Header Start
;estimated_time(s): 6.117
;MAXX: 114.44
;MAXY: 114.33
;MINX: 35.67
;MINY: 85.56
;Header End
G92 X0 Y0 Z0
G90
G0 F3000
M3 I
G0X35.667Y85.555
G0X64.222
G1X64.333S299
G0X114.222
G1X114.333Y85.555S299
G0X35.666Y114.222
G1S299
G0X85.555
G1X85.666S299
G0 F3000 X35.711Y114.289
M3 S300
M5 I
G0 F3000 X0 Y0
Maybe you´ll want to try a Custom GCode with a Snapmaker (Marlin) based profile?
Edit: with your LightBurn 3 circles job click Save GCode and post here the the file.
