I have the Ortur laser master 3. Many times happens that I do framing, the laser is not starting (the laser light) but sometimes it does. when I actually start the laser then also, sometimes it works, and sometimes not…can I do something about it?
Are you using multiple device profiles?
One with laser enabled on while framing (with power percentage) and another without (in Device Settings)?
You can enter $I in your console window to learn your firmware version and decide whether or not you should update your laser’s firmware. Support-OLM3
Well, only one cevice as i described. the orture laser muster 3 and the laser on when framing is on.
