The laser is only framing and not firing
I just purchased the OmTech 50-watt galvo and following the set up instructions everything seems to be fine except for when I hit start it does nothing. I am only using an aluminum business card to make a square. You can see the framing of the square, but when you hit start you can see the laser start to do something, but nothing happens.
Does the laser window show it’s uploading the file? Maybe ready?
It’s really hard to tell if it’s actually lasing or out of focus. It’s likely out of focus. Depending on the lens it could have a depth of focus (dof) of less than 1 mm for a 100mm lens. That makes focusing critical.
Here’s a video on how to do it with a fiber from Laser Everything. Lots of great information comes from them.
In simple terms, you just move it up and down until it makes the most noise. Usually a lower frequency and a higher pulse q-pulse rate, if that’s adjustable on yours.
You need to load the proper configuration file that came with it when you created a new device in Lightburn.
Sing out if you have more issues…
Good luck.
:grinning_cat:
I have the same problem!
My sculpfun Laser doesn’t fire with my Desktop-Computer.
(Trial Licence Lightburn Pro 2.1.04)
In common with my Laptop it is working fine!
On the Desktop-Computer I can do everything but no fireing.
Go to home position, move step by step in X-direction or Y-direktion or set the Center of the image is working…
Only when I try to start burning the laser goes to startpoint an then nothing else happens.
The streaming from LightBurn to the Laser comes not to end an the only way to restart or to do something else on the Laser is to switch off the Laser and to restart LightBurn.
On my Laptop I doesn’t have this issue, on the Laptop burning works very well…
Please give me a tip, what can I do?
Many thanks!
Konrad
In addition:
With the poor and simple Software of Sculpfun I can start and do burning from the Desktop.
So I think, that is only a problem in LightBurn.
The console parameters ($$) on my Desktop and Laptop are identical…
Welcome Konrad.
You should have made a new topic.
Anyway… Your best bet is to migrate settings from laptop:
Thank you very much for your answer!
This tip with the bundle was very good, after of about 5 minutes my laser burns!
But there is a problem left: After burning the image, the streaming is not closed and i have to switch off the laser for a next trial. The streaming process stucks at 83%…
Do you have an additional tip?
Many thanks,
Konrad
In the meantime I did some other trials: I modified the energy-options on all COM adapters… No sucess
Then I tried a second USB-Cabel… No sucess
Afterwards I moved the USB-Cabel to the backside of my desktop… no sucess
Then I checked my desktop for optionaly windows-components (media package etc.)… every thing is installed…
I removed although all other USB-Components… no sucess
I think, I have to give up, no idea, whatever I could modify instead…
Konrad
How long is the USB cable run from the desktop compared to the notebook? The recommended maximum is 10’ (3 meters), even though the specification says 15’. You replaced the USB cable, but was it with a quality shielded cable with a ferrite (big knot or bump) on it?
The cables were about 60’, 1,5 meters…
The both cables are completly shielded with copper-net. There was a ferrit knob although!
The same 2 cables are working on my Laptop whithout any problems!
It seems, that the problem is not in Sculpfun or in LightBurn but between Lightburn and Windows Professional 10…
Best regards,
Konrad
60’ is over 18 meters…?
Probably 1.5 meters or ~4’11", which should be OK.
I have a fiber that acts up now and then. One weekend I spent about an hour and found the usb on the receptical at the fiber controller itself was a bit loose.
I have HF and UHF transmitters in my room and have never had an issue, although USB on windows can be a problem, I’ve never really had an issue with the cable itself.
However, @MikeyH is correct, it’s always wise to start with the easy stuff, rather than make assumptions on what it is. Unlikely it’s USB, if it’s working on other machines of the same bandwidth.
Good luck…
:grinning_cat:
You can enable view all in Console Window and check the code emitted when the stream stucks at 83%.
