The layers does not save after last update
Hello everyone. Does someone has the problem with layers, does not save?
I am making to be 25 speed for layer 01, after a new downloading again it is 500.
I try anything i can do, reset layer, save, save as, OK, restart, all the same.
Every layer stays as i made them before the last update, and now i can not change it.
Thank you.
I think i found a solution.
I opened LightBurn from the dekstop icon, change the layer and then closed, without any download to make.
After i make a download, the new layer stays saved.
Layers are only saved with your project. If you create a shape and assign speed / power settings to it and save it as a project, those settings will be stored in the project file with it.
Can you explain what you mean by “after I make a download”?
Download of the object from CorelDraw via CorelDraw macros.
Yes, i am agree can be a reasonable explanation, but it was not like that for the last 2 years.
Before the last update, i was placed what ever speed and power or dot mode or direction or what i want, and just pressing the button OK, everything was saved, forever.
Now, when i download an object from CorelDraw, the layer does not save from the previous work i want.
It was a big problem for me this days, every time i am fulfil the speed, the power and the dot mode again and again. For that reason i asked here.
Go to Edit > Settings, and tell me what your setting for this is:
Is that switch toggled on or off?
This is off. I never use that option there.
But after maybe the last update today, everything looks goes back to normal again.
I try multiple times, everything saves just fine.
Thank you for your time.
It was very helpful for me, i am using a lot of layers.
