After the update, I started making a project. I adjusted the focus, turned on the “red dot” positioning. Everything is fine. The layout on the material matched the frame, but as soon as I moved the layout to another place, my layout and the red dot did not match each other. I tried to create a new device, nothing helps.
Double posting doesn’t help either.
I tried it doesn’t help
I found the problem. As soon as I try to change the scale of the red dot to 0.960 and 0.985, there is a positioning problem. Now I use the settings “red dot” from the lens 100100, but this is not correct. A 150150 lens is now installed
