The Red Dot from Click-to-Position tool is not moving
Hy there !
I have a Sculpfun S9 and I use it for hobby , but i have a problem with my red dot. It is stuck in the origin position even if my laser is in the middle of the board.
It worked well until now , showing me the exact position of the laser, but now is stuck.
Can you help me ? Did someone else ecounter this issue ?
Thank you!
I don’t understand. Do you mean a software function in LightBurn? Or the hardware positioning laser dot?
I assume this is referring to the Last Position indicator.
Can you make sure you have “Show Last Postion” enabled in Laser window?
Thank you! That was the problem. You are a life saver
