The Standard Nozzle Trap: Why Your Machine Fails and Why I Had to Invent My Own!
Focus Down Part 3: Nozzle & FRL — The Hidden Trinity
In my first post, I mentioned using a 0.2mm gap. For this to work, your nozzle must be wide. A narrow nozzle is the enemy of that 0.2mm precision. Test it yourself; I am giving you the theory.
Part 1 – Machine Feet and Daily Discipline Check the ground before the nozzle. If your machine isn’t fixed, the nozzle is useless. Rule #1: Spirit level. If your machine is tilted, focus drift is inevitable. Especially on Z-axis machines, this deviation ruins everything.
My advice: Keep a spirit level on your machine at all times. Every morning, check it with a glance. Factors like machine vibration or a belt loosening over time can ruin your precision in an instant. If you have a Z-axis machine, you must also check the table; this is the biggest problem for focus. No one tells you this; go face your level.
Part 2 – Why Narrow Nozzle Fails A narrow nozzle exits air like a needle—there is no “brush effect.” In a wide nozzle (which I had to invent), the air spreads and clears the smoke. This is essentially painting with air. For those curious about the details, re-read the massive air power post in Part 2; I explained there how I turned that power into a brush.
  • Narrow Nozzle: No brush effect, weak/matte colors.
  • Wide Nozzle: Active brush effect, deep and rich colors.
Part 3 – Grinding the Nozzle and Extra Air Needle-point air will not allow you to process the material correctly. I ground down my nozzle to widen it. This is the only way to effectively use the massive airflow from the extra compressor I described in Part 2. I’ve used the same modified nozzle for 10 years. The result? Deeper engraving and exact tones.
Part 4 – FRL (Air Filter Regulator) and Lens Shield Install an FRL unit as CLOSE to the nozzle as possible. Oily air is the enemy of your lens. Think about it! Air doesn’t just go down; that high pressure also fills the laser head cavity. In this method, the clean airflow is the only thing that acts as a shield and extends the lens life.
Important Warning: Master’s Precision vs. Standard This system is for general engraving; delicate glass engraving is a different world. In standard jobs, people settle for 0.2 interval and move on. But I am talking about 0.02 interval, 55 power, and 150/200 speed on glass. Only those who have perfectly set up this system can understand the quality created by this 10x precision difference. The secret lies in the custom-made “buji nozul” (spark plug nozzle), which I also had to invent; I will explain this later if there is enough interest. Keep in mind, my machine is 100 Watts; you can imagine what it means to manage this power with such precision.
The Result: Triple Power We pulled the focus down (0.2mm gap), powered up the air, and widened the nozzle. If you set up the full system, you will see a 4-minute job finish in 35 seconds. This is not a claim; it is the mathematics of 15 years of experience.
Summary
  • Secure feet, kill vibration.
  • Keep spirit level on machine, check frame and table every morning.
  • Widen the nozzle, catch the brush effect.
  • Keep FRL close, send clean air to the lens.
No proof, just theory. Those who believe will apply; those who succeed will master. I show the way—you hold the wheel.
Murat KOR www.lazerlibaski.com/masters-secrets.html
Vesselam.
You are saying you are making 90% overlapping passes and not saying you have a .02mm spot diameter on a CO2 laser, right?
Surely the end of the nozzle needs to be a set distance from the material (over the whole area), so the bed should be leveled to the nozzel rather than the nozzle to the ground. All my CO2 lasers are chocked up slightly on one side, to help ensure that all air bubbles leave the tube.
I haven’t gotten a tube that didn’t have a this side up indicator. It should not need to be tilted.
The concern is bubble(s) stuck the center glass area where it’s lasing.
:grinning_cat:
