The laser fires when I disconnect the power supply from the ruidia motherboard. When I say it fires, I mean that when I press the test button on the power supply it fires. If it is connected to the motherboard it will not fire either while running, pulsing or testing via power supply.
I am guessing that either something is wrong setting wise or the motherboard is bad.
- Max power is set to 30, Min is set to 25
- When max power is set to 99 the laser fires at 01Ma
- When testing just the power supply we put the Ma up to 6. (It will not adjust while connected to Ruidia.
- The cabling is correct based on diagrams and pictures I’ve seen.
Let me know what additional information is needed to troubleshoot this.
Thanks in advance.
