I get this error occasionally which is fine, usually if I reset the device it solves the issue. However what will happen is when I send the job to the laser it will start the job, then a couple seconds later give me this error. The issue is that since it has already started by the time I get this error, and rush over to stop the job it has already engraved a few lines.
Is there a way to set LightBurn to wait until it is sure the whole file is sent before starting on the laser?
I have the laser hard wired via Ethernet with a static IP that is not being used by another device.
