"they fear the glass will break, but we leave our signature"
Everyone knows that a laser leaves a mark when it hits glass. A slightly whitish powder, a little beveling… Most people call it a “print.” But I say: it’s just a simple scratch on the glass.
If your fingernail doesn’t sink into that scratch when you touch it, if you can’t achieve the depth of the old grinding masters (search it on YouTube, you’ll definitely see it, it’s in the memories of the elderly), then you’re not doing justice to either the machine or the product.
Learning Doesn’t Cost Anything: I Wasted Hundreds of Glasses
No joke, it’s true. I sacrificed hundreds of glasses. A piece of advice from a master to those who doubt they can do better: I paid this price until I reached that depth where my fingernail could sink. Because when you want to penetrate the heart of the glass, you have two big enemies: Heat and Excess Air.
Air Isn’t Always Your Friend
I’m not speaking in commercial jargon. I managed to get inside the glass with my own machine settings (200 speed, 55 power, 0.02 pitch).
As you know, I’ve explained in my other articles: I generally use a wide nozzle with a ground edge for surface cooling. But things changed with this depth work.
Now you’ll say; “Why did you give up on surface cooling? Wouldn’t a wider area cool better?”
That’s not how it is, masters. The pitch is very short (0.02), the laser hits the same spot like crazy. While trying to cool the surface with a wide nozzle, the heat at the actual point where the laser hits accumulates even more. Precise intervention is necessary!
That’s where I went on the “Spark Plug Nozzle” discovery. For those “rebellious Janissaries” who insist on measurements:
You know that small screw-on tip that connects to the wire at the end of the spark plug? I removed it and fitted it to the nozzle, narrowing the hole. The spark plug withstands high temperatures, so it was the most robust. But if you don’t keep the airflow in that narrow opening in the right amount, the heat buildup collides with the cold air at that point, and you end up with a broken glass – thermal shock and its consequences…
Now, I could explain this using fluid theory (let’s not get into patent complications)))))))) The result? 20-30 more glasses wasted.
I Learned to Trick the Machine and the Glass
I saw that neither heat nor air was saving me; so I said, “I need to trick both the machine and the glass.”
I placed an empty square with zero power 15-20 cm ahead of the process. Every time the machine head went to that empty space, I captured the glass cooling naturally. That’s when I started pushing the limits. In 0.02 steps, I both rested the glass and got that deep, crystalline etching in my hand.
Answer in Advance to Those Who Will Ask
“How many bars of air?”
This won’t work with a standard aquarium pump. You absolutely must add a compressor. Don’t ask me what capacity it should have; determine that according to your own workload. You’ll know the correct airflow setting by the “whistling sound.” Not too little, not too much. “WHERE THERE ARE VARIABLES, THERE IS NO SINGLE RIGHT WAY.”
“Why an empty square? What should the distance be?”
That empty space you call a “waste of time” is the only moment the glass can breathe and dissipate that deadly heat. I wrote 15-20 cm for the distance, but that’s the value that works on my workbench. You decide. Do as much as the glass requires. This is your job. You know your machine, your materials, your environment. Place the empty square far enough away for the glass to cool down. You’ll find the right distance quickly. If you don’t provide that space, you’ll hear that famous “click” sound at the end of the job, and your effort will be wasted.
“WHERE THERE ARE VARIABLES, THERE IS NO SINGLE RIGHT WAY”
Remember: every machine, every material, every environment is different.
Even two machines from the same factory are not identical (there are acceptable values). That’s why you shouldn’t trust those who tell you to set certain things by rote. The key is understanding the principles. Hearing the sound, not the numbers. Finding inspiration, not a ready-made recipe.
And let me add this: Every experimenter will become a new master.
Experiencing, breaking glasses, hearing the whistling sound, finding your own truth… That’s what mastery is.
In the end…
Maybe 100 glasses were wasted. But today I have a signature product that has increased its price fivefold compared to the market. I both recouped the cost of the wasted items and dazzled the customer by doing what was considered “impossible.”
This article contains tips. You will try it and see, and you won’t even believe the result.
We are not standard masters. We don’t have parameters; we have whistling sounds, listening to the sound of a belt. “WHERE THERE ARE VARIABLES, THERE IS NO SINGLE TRUTH.”
We’ve etched our signature deep enough to fit a fingernail.
That’s all.
Murat KOR – lazerlibaski.com
