Thunder Nova 63 RotoBoss Rotary in 2.0.05 not working but does in 1.7.08
I have a Thunder Laser Nova 63 that is from 2021 and I have the RotoBoss rotary from same time period. Using Lightburn 1.7.08 everything seems to work fine when I updated to 2.0.05 it does not function properly. If I go back to 1.7.08 it works fine which is what I have done to get jobs done but I would like to update for the new features.
The problem I am seeing is that going to the move window I hit the counterclockwise button to rotate once and it does that but hitting it again it will not turn. If then hit the clockwise button it will move the first time but not subsequent times. I checked the rotary setup and it is choosing the A axis, which matches what I have in 1.7.08, and it is the only option allowed to choose. If try to run a job it seems to frame correctly but since I can’t use the move reliably I don’t trust the setup to run the job. I am not sure if I am missing a new setup step that is part of 2.0 or if this is a bug that is still being worked out.
