Tiling on MOPA JPT/Fixed column machines with Camera
Can a feature be implemented in which you essentially get an infinite Y assuming you have a jig for orientation alignment(keeping the workpeice in the exact orientation every time)?
You could do so by making the workspace 10mm smaller than the maximum output size of the lens and then moving the workpeice so the bottom of the last part etched is still visible by the camera which can then adjust within that 10mm margin of error available (say 100x100mm for a 110mm) to match up the current area with the next available area of the design allowing for an infinite Y axis.
There should be no reason this shouldn’t work. However, the fiber coverage limits what you can do.
My work area is 300x300mm using an F420mm lens. If I did that size, I could only get one row because it’s at it’s maximum Y range.
The real question is can you register it. If you need perfect registration, like a large photo, it’s more difficult than separate photos. If you off 100 nanometers (0.0001mm), you eye will usually pick it out.
Generally the idea should work, you could try something like print and cut operations. I don’t have a camera on any of my lasers, so don’t know much about it.
Some of the other folk here might be able to come up with a better solution…
Good luck.
:grinning_cat:
Print and cut is what inspired the idea, if the software can trace and cut with a gantry, why couldn’t it trace and add the next tile in the correct area if it’s given a margin to work with? Fiber coverage limits your X but if your Y becomes infinite then all you need is a passthrough in your enclosure and you can just feed, burn, feed, burn and repeat. All it needs is guaranteed alignment to the initial spot so you would use the included fixture holes and make a fence and just ensure you’re always aligned to that fence.
Granted a 4k camera at 220mm focal distance say for a 110mm lens will be 0.039mm per pixel or about 1.5 thou, I’m sure this would be more than close enough for almost anyone not doing 3d work.
I get most of my lenses from Cloudray. An F163mm has a coverage of 112x112mm. There is little room at this height for any kind of manipulation of materials.
Another thing to think about is how do you plan on making a jig that is only square to one side. If you need to move it in the X direction, you have no stop for registration or indexing.
I might not be understanding you, but in either case you might want to go to Feature Suggestions, on the sites main tool bar and enter the suggestion there, where everyone can vote on it.
Hang in there, you’re likely to get others chime it…
:grinning_cat:
I would go about it another way using split marking and a conveyor setup, if I understand your goal correctly. Same limitations apply but everything LB already in place, just have to build the conveyor which probably not too tough.
It’s about making it simple, which is the purpose of lightburn to begin with, not everyone can afford a conveyor but everyone that can afford a fiber laser can afford a camera. Granted the components of a conveyor are simple, it can be daunting for someone to consider this, best case scenario your laser can control it via its 4th axis but you need to know trig, you need to know mechanical engineering to some degree etc.
Other then knowing Mr. Trig, most of what you say is probably correct. I probably misunderstood your goal. I pictured a banner shaped engraving. I don’t believe manually moving the workpiece several times and attempting to align with a camera would produce decent results, and would be really, really tedious. Just my opinion of course, doesn’t mean you shouldn’t give it a go. I think they do it with open ended CO2 machines.
I only suggested moving with mechanical means is because it is routinely done with LB / galvos
Have you seen this?
Support for a flying galvo head mounted on a gantry machine.
:grinning_cat:
Yeah I have my issue is that my laser would require mounting the source on the gantry too which would require increased rigidity and extremely effective dust extraction which may block the camera to some degree. The cost would be ineffective I believe.
I’ve been watching Gantry/ galvos for a couple years now, big :astonished_face: money and still doesn’t solve the “Banner” work area. A Texas laser company quoted me over $70K and that had less work area total then my X table and the 175X175 lens in either direction.
I mean I’m a machine builder and worked for SPR (Austin based company) at their R&D factory in Canada. It’s actually fairly reasonable in that scope but in my hobbyist scope it isn’t. I could build that for you for under 10 operational. The hardest part is software but, Wiring, Servos/steppers, extrusions/steel frame, mounting options, ballscrews, linear rails etc. EZPZ. There’s quite literally zero reason to use higher end stuff for most of it and that’s where these companies get you, Genuine Hiwin RGR20’s on a machine taking no forces aside from jerk are absolutely ridiculous. A higher end ballscrew okay if you want your accuracy to be within a micron or whatever you get ground screws but otherwise nothing in that quote makes sense aside from someone else doing it and pocketing the diff. There is zero need for support if you understand all the components of a machine and that’s a biiggg chunk of that money (often times they charge you for the support anyways)
