Is there away you can see the time on machine before you cut
this is need to quote client before cutting?
When you go to Window / Preview, it gives you an estimate of the time required to cut.
If you have a Ruida controller, the laser itself can tell you as well - You can Send the file to the machine, then go to the File List window, select the file and click ‘Calc time’. It may take a couple minutes if it’s complicated or an engraving. When it’s completed, refresh the file list and the computed time will be displayed. The preview window in LightBurn, if you’ve tuned it to match the controller, will give a relatively accurate time as well.
