Given that you wrote “Much of the camera capture code has been rewritten,” do we need to rerun the “calibrate camera lens” AND the “calibrate camera alignment” routines? Just one? Both?
“The camera lens calibration now has a special setting for fish-eye lenses” - Of the cameras you sell, which ones do you classify to be “fish-eye”?
You don’t have to re-calibrate if it’s working well for you, might gain a little better accuracy or usable bed area if it’s clipping yours out and you have a fish-eye lens.
120, 140, and 160 are all technically fish-eye lenses. The fish-eye correction is part of the lens calibration process, so if you recalibrate you’d redo both the lens calibration and the alignment calibration. (The first is used by the second)
The fish-eye specific calibration mostly affects the outer edges of the lens correction, and allows the entire output to be used.
LightBurn would previously only use the parts of the image that were completely valid, within the red rectangle. The new code allows the use of the entire image, so you may get a small black indent in the middle edges of the image, but you’ll get more usable area in the corners.
