Tipka okvir pri programu Lightburn
Pozdravljeni. Pred dnevi sem posodobila Lightburn na novo različico in me je zmotilo to, da ko narišem ali napišem nekaj in pritisnem okvir kjer naj bi laser naredil to obliko ali napis, laser naredi okvir v smeri urinega kazalca kar me zelo moti, ker pred posodobitvijo je bilo ravno obratno in sem lažje nastavila les pod objektiv. Se da to mogoče kaj urediti ali ne. Hvala za pomoč in lep pozdrav.
Hello. A few days ago I updated Lightburn to the new version and I was bothered by the fact that when I draw or write something and press the frame where the laser is supposed to make this shape or inscription, the laser makes the frame clockwise, which really bothers me because before the update it was the other way around and I could more easily position the wood under the lens. Is there a way to fix this or not? Thanks for the help and best regards.
Which direction should make no difference, even if you are placing the wood while it is framing (which is not a good idea).
I place my material in the same location (corner it Homes to) and move the part in Lightburn to get it to match. I then save the file with Absolute Coords selected and have a repeatable setup for when I make the same part later in time.
