Tips for measuring ramp test distance
Any tips or tricks for measuring from the nozzle to the material when determining focal distance? I’ve tried calipers from a stationary point on laser head but it doesn’t seem as accurate as it should be. Hoping for some ideas to take the guess work out.
Thank you
If it’s easier try measuring from ramp height to ramp base. Then subtracting that from bed to nozzle distance.
I set the ramp, run the laser across it. Move the laser head to the best focus position then use Drill bits between the head and the ramp to give me the distance.
Eg, if I can fit a 9mm Drill between then obviously 9mm focal from end of lens tube. If your distance is bigger then fold a piece of paper to fit between the lens tube and the ramp then measure that.
great idea, thank you
