When working a project and starting it at the center of the material, the laser module would return to that starting point once the task was completed. I don’t know what has changed besides the latest light burn update 17.1, but now the laser module doesn’t return to the starting point. If I wanted to run a second pass for some reason, nothing would line up with the work that was just completed. Please help.
Where is it going?
What do you have your start from set to?
Do you have this set?
The laser module stays in the position that the project was completed and doesn’t return to the center of the material where it started. I’m not sure what the XY settings are, but I will check them right now
