When using the Trace Image preview window, how do you pan once the image is zoomed in? I know the documentation says to use the middle mouse button to pan, but currently Windows doesn’t recognize my middle mouse button (which is also the scroll wheel…I may need to install a driver) and the spacebar doesn’t work for panning as it does on the main UI. Is the mouse button the only way to pan once you’re in the trace image screen? When checking the traced lines I like zooming in to see how well it did and then moving around to different parts of the image. Thanks in advance for the help.
Middle or Right mouse button works for me.
