Tracing JPG - Not retaining original image
When I used to open a JPG file in LB, I could trace it and move the traced image and save both images. Now, when I trace a JPG and try to move it, it no longer saves the original image. Please let me know what has changed (a setting)?
Make sure the option “Disable image after trace” is not enabled in the Trace window.
That’s what it was. I must have changed this by mistake. Thanks a lot for the quick response.
As @berainlb points out, (wording is slightly different), ensure you have ‘Delete image after trace’ is turned Off (red) to keep both the original and traced art. :slight_smile:
