I there any way that you can Trace the outside of a job without power to the laser? I know you can BOX the image, but if you have a job that is spaced out it that doesn’t help in where to place the leather to get the most efficient use of leather. Large areas of leather could be in the box but not used. IF this is not in the software HOPEFULLY it can be added.
Sort of:
The rubber-band boundary is what would result if you stretched a rubber band around the vectors of your project. For example, if I have these shapes:
Then this is the rubber-band boundary:
It’s a much better fit than just a box frame, but it doesn’t do ‘indents’ (concave areas) in a design.
