Trato de cortar un cuadro o alguna figura y la hace 2mm o 3mm más grande de lo que aparece en el archiv (I try to cut a picture or some figure and it makes it 2mm or 3mm bigger than it appears in the file.)
Tengo una gemnitsu jinsoku LC-60A. Al principio cortaba a la medida correcta. Luego de tratar de usar el eje rotativo pierde la configuración. Introduzco $$ para que retorne a los ejes XY pero las figuras o formas no salen a la escala correcta.
Tal vez alguna configuración que no sé en LightBurn. Sucede lo mismo con GRBL.
I have a gemnitsu jinsoku LC-60A. At first I cut to the correct size. After trying to use the rotary axis it loses the configuration. I enter $$ to return to the XY axes but the figures or shapes do not come out at the correct scale.
Maybe some setting I don’t know in LightBurn. The same thing happens with GRBL.
Gracias
Thank you
Than you.
Customer service solve my machine issue.
After using the rotary, the setting to stop using it is on the Rotary Setup menu.
2023-02-28_16-55-36
$$ only requests a report of Machine Settings from the controller.
It shows what is present in the controller.
If the factory settings on your engraver were excellent and worked well for you, entering $RST=$ will return them to the settings the engraver had when the firmware was flashed.
Thank you very much John.
Good to know. Im going to be alert on that settings.
