Travel issuse on the Y axis on a Ortur LM2
I am having trouble with it seeming to bind when the X axis reaches the Y axis on my Ortur LM2.
I have done some troubleshooting checking belt tension. Even swapping the stepper motors to see if the was an issue with one of them. It still acts the same after the swap. It just binds or and stops and seems to struggle to continue to reach the home position.
I have tried to run a simple line to see if it would burn it but i get this error:
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Ready!
OLF 142.
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Any thoughts and suggestions would be greatly appreciated.
Thank you
Michael
With power off does each axis move by hand smoothly?
Yes it moves normally in all directions.
