Is there a command to make the laser stop burning the line it’s on, because it’s already burned through, and go to the next burn in line?
Many lasers are different on what you can and can’t do. Generally, no you can’t do what I think you’re proposing. I don’t think I can stop my Ruida when it’s in ‘run’ mode, but via Lightburn I can ‘send’ it a layer to run or re-run. I can pause the ‘run’ of the Ruida. Can’t really change anything about the run from the console or via the software connection, unless you stop it. Then it’s all reset like you haven’t run it.
It’s helps a lot to know what laser/controller you are using. We don’t know what’s on your desk.
