Hi everyone, been using Lightburn with a Ruida Controller with perfect results for the past 5 months. Now I got another machine running the latest Trocen Controller 7813. One of the things I noticed is that Lightburn looks slightly different and has a few different options than when running the Ruida, I’m assuming its Controller specific. I’m connected via Ethernet on a Mac with IP address on the same range.
I’m hoping someone here has some experience with Trocen and can lend a hand.
The main issue I’m having is connectivity. Even though Lightburn shows “ready” there’s always an issue connecting to the controller. Not once in a while but always. I press start to run a job and I get the message “machine is busy or paused” or “file transfer failed”. After trying over and over for 10 to 15 times it eventually starts. Getting position from the controller to Lightburn is the same issue. Lightburn is not receiving data from the Controller.
Another issue in X-axis direction. It runs backwards if jogged from lightburn. If I change the settings on lightburn then it runs backwards if jogged from the controller.
Kinda puzzled right now… Thanks in advance for any help.
