I’m using a X-Carve 1000mm x 1000mm, GRBL 1.1f, with a JTech 4.2 watt laser. I’ve almost have all the bugs worked out but now the laser won’t turn on when running a GCode or by using the fire button in the “Move” window. However it will turn on and stay on if I slide the mode selector switch on the JTech controler to “Manual” mode. It will flash on startup of the software. The button in Lightburn is enabled in the “Device Settings” and is set at 3.00%.I tried changing it to 8.00% that changed nothing.
$0=10
$1=255
$2=0
$3=4
$4=0
$5=0
$6=0
$10=0
$11=0.020
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=3
$24=25.000
$25=750.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=40.000
$101=39.863
$102=188.976
$110=8000.000
$111=8000.000
$112=500.000
$120=500.000
$121=500.000
$122=50.000
$130=790.000
$131=790.000
$132=100.000
Settings under Laser Macro are,
$10=0
$30=1000
$32=1
G10 L2 P1 X-790 Y-790
Thank You
Tom
