Hi Get error message DOcheck32.exe
the code execution cannot proceed because libgcc-dw2-1.dll was not found. Reinstating the program may fix this problem.
help please
help please
My system is 64 bit, but have downloaded & installing the same as every other time, but comes up with this message
cheers
I had this issue when it downloaded the 32 version on upgrade, I just went onto the website downloaded the 64 version and that installed fine.
Hi , i have the same problem on a windows 7 , 32Bit.
The installers for the 32 bit and 64 versions have been fixed. Try downloading and installing again.
I still am getting an error every time I try installing, “An error ocurred while trying to replace the existing file: DeleteFile failed; code5. Access is denied” HELP!!
That usually means LightBurn is still running. It can also mean that Windows Explorer is using the Thumbnail generator.
Try this: Uninstall the current version, then install the new one - that usually clears this kind of error.
