I have a d1 pro 20w machine added the extension kit and am trying lightburn since I can modify the canvas size from the 930mm to the actual machine limit of 940mm as my part is 934mm.
My issue is if I run my file on lightburn with a cut speed of 500mm/m 2 passes and 100 power the machine or software stops and the machine return to what it thinks is home. If I restart the laser and run the same file at 2000mm/m or higher it has no issues and completes the burn.
If I run the same file rotated 12.5 degrees to fit the canvas on XCS there is no issue
What could possibly be the issue with running the cut speed slower?
