I bought (I know! Sad, innit!) a file from etsy that is only in DXF format.
Ostensibly for 3mm material, it imports at much larger.
Obviously it’s going to be an inch v mm thing, you would think, right? But the vendor is Spanish and uses mm only, as do I and swears the file is good.
I got him to save it as SVG and it imports perfectly and the measurements are correct - so he has it in his machine at the correct dimensions, but between his machine and mine, via DXF, it screws up.
The particular file I bought isn’t of any consequence, as I only bought it to bring my purchase price up to where I got a 40% discount on what I did want…
I’ve imported the SVG and exported it as DXF and there’s definitely some differences in the file format.
Can I send it to you at support@ and have you determine where the problem lies?
