Troubleshooting laser going wild
Hey everyone, I’m very new to laser engraver. I picked up one of those craigslist deals on a sculpfun s30 pro. Appears to be barely used. Guy seemed pretty legit said everything worked well for him. When I set up at my house, I downloaded light burn and it’s the first time I’ve used the program. Every time I try to create an image, after about a minute to 2 minutes, my laser starts going crazy and starts to just randomly go everywhere basically. When I make circles, after the same amount of time it’ll start making ladder steps. Any help or information would be greatly appreciated whether this is a software thing or a mechanical issue with the laser.
Things ive checked :
-Stepper motors do not feel hot as far as i can tell
-Tightened belt that drives both X and Y axis.
-Checked set screws in pulleys on stepper motors
All checked out so far, but should i potentially double check one of those particular things? Maybe when i have one or 3 less beers in me from frustration over the hours i’ve been trying to figure this out :rofl:
Go through all of these steps:
It looks like there is a mechanical issue, it should not be caused by the software. But anyhow, show your LB window and the settings for the project. Maybe speeds were too high or so.
When diagnosing the machine, Use 2" squares and circles, 1 pass. Then post a pix of what you get.
Also use Amazon cardboard for your test material. MUCH cheaper than any wood you can buy.
Thank you all for the responses. Here’s a little bit more of what i did between last message and now.
Used machine oil on rail of laser. Tried the “tilt test”. Was able to get the Y-axis to fall slowly at a 45 degree angle. Was not able to get the laser itself to fall down rail. Lube rail, loosened Laser belt a bit, still does not fall freely. Let me know if this could be the main issue.
Also changed out my USB cable to a brand new short one.
The picture above is the result after all of that.
The laser starts out perfect, but every time after about a minute and 15 - 2:15 (In this pictures case it happened around 1:46 seconds in)
You can hear the laser physically change its sound. Its no longer a long consistent buzz, but more of a mechanical revving and random laser bursts. I do have a video of this issue, but am not able to upload it to the forums.
Also, thanks for the Amazon cardboard tip, had a giant pizza box ready to be burned :slight_smile:
Thank you all again for the help, and any guidance would be absolutely greatly appreciated.
Also, heres a copy of the console log after the project above
Summary
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
G00 G17 G40 G21 G54
G90
G0 X62Y673.598
G1 Y798.402S0F5250.03
G1 X418
G1 Y673.598
G1 X62
G90
Stream completed in 0:00
Starting stream
G00 G17 G40 G21 G54
G90
M4
M8
G0 X107Y582.077
Layer C00
G1 X106.967Y580.818S1000F900
G1 X106.871Y579.574
G1 X106.712Y578.349
G1 X106.492Y577.144
G1 X106.213Y575.959
G1 X105.876Y574.798
G1 X105.483Y573.66
G1 X105.035Y572.549
G1 X104.535Y571.464
G1 X103.983Y570.409
G1 X103.381Y569.384
G1 X102.73Y568.391
G1 X102.033Y567.431
G1 X101.291Y566.506
G1 X100.505Y565.618
G1 X99.678Y564.768
G1 X98.809Y563.957
G1 X97.902Y563.188
G1 X96.958Y562.461
G1 X95.978Y561.779
G1 X94.963Y561.142
G1 X93.916Y560.552
G1 X92.839Y560.012
G1 X91.731Y559.522
G1 X90.596Y559.083
G1 X89.434Y558.698
G1 X88.248Y558.369
G1 X87.038Y558.095
G1 X85.807Y557.88
G1 X84.556Y557.724
G1 X83.286Y557.63
G1 X82Y557.598
G1 X80.714Y557.63
G1 X79.444Y557.724
G1 X78.193Y557.88
G1 X76.962Y558.095
G1 X75.752Y558.369
G1 X74.566Y558.698
G1 X73.404Y559.083
G1 X72.269Y559.522
G1 X71.161Y560.012
G1 X70.084Y560.552
G1 X69.037Y561.142
G1 X68.022Y561.779
G1 X67.042Y562.461
G1 X66.098Y563.188
G1 X65.191Y563.957
G1 X64.322Y564.768
G1 X63.495Y565.618
G1 X62.709Y566.506
G1 X61.967Y567.431
G1 X61.27Y568.391
G1 X60.619Y569.384
G1 X60.017Y570.409
G1 X59.465Y571.464
G1 X58.965Y572.549
G1 X58.517Y573.66
G1 X58.124Y574.798
G1 X57.787Y575.959
G1 X57.508Y577.144
G1 X57.288Y578.349
G1 X57.129Y579.574
G1 X57.033Y580.818
G1 X57Y582.077
G1 X57.033Y583.337
G1 X57.129Y584.58
G1 X57.288Y585.805
G1 X57.508Y587.011
G1 X57.787Y588.195
G1 X58.124Y589.357
G1 X58.517Y590.494
G1 X58.965Y591.606
G1 X59.465Y592.69
G1 X60.017Y593.745
G1 X60.619Y594.771
G1 X61.27Y595.764
G1 X61.967Y596.723
G1 X62.709Y597.648
G1 X63.495Y598.536
G1 X64.322Y599.387
G1 X65.191Y600.197
G1 X66.098Y600.966
G1 X67.042Y601.693
G1 X68.022Y602.376
G1 X69.037Y603.012
G1 X70.084Y603.602
G1 X71.161Y604.142
G1 X72.269Y604.633
G1 X73.404Y605.071
G1 X74.566Y605.456
G1 X75.752Y605.786
G1 X76.962Y606.059
G1 X78.193Y606.274
G1 X79.444Y606.43
G1 X80.714Y606.524
G1 X82Y606.556
G1 X83.286Y606.524
G1 X84.556Y606.43
G1 X85.807Y606.274
G1 X87.038Y606.059
G1 X88.248Y605.786
G1 X89.434Y605.456
G1 X90.596Y605.071
G1 X91.731Y604.633
G1 X92.839Y604.142
G1 X93.916Y603.602
G1 X94.963Y603.012
G1 X95.978Y602.376
G1 X96.958Y601.693
G1 X97.902Y600.966
G1 X98.809Y600.197
G1 X99.678Y599.387
G1 X100.505Y598.536
G1 X101.291Y597.648
G1 X102.033Y596.723
G1 X102.73Y595.764
G1 X103.381Y594.771
G1 X103.983Y593.745
G1 X104.535Y592.69
G1 X105.035Y591.606
G1 X105.483Y590.494
G1 X105.876Y589.357
G1 X106.213Y588.195
G1 X106.492Y587.011
G1 X106.712Y585.805
G1 X106.871Y584.58
G1 X106.967Y583.337
G1 X107Y582.077
G0 X168Y581.077
G1 X167.967Y579.818
G1 X167.871Y578.574
G1 X167.712Y577.349
G1 X167.492Y576.144
G1 X167.213Y574.959
G1 X166.876Y573.798
G1 X166.483Y572.66
G1 X166.035Y571.549
G1 X165.535Y570.464
G1 X164.983Y569.409
G1 X164.381Y568.384
G1 X163.73Y567.391
G1 X163.033Y566.431
G1 X162.291Y565.506
G1 X161.505Y564.618
G1 X160.678Y563.768
G1 X159.809Y562.957
G1 X158.902Y562.188
G1 X157.958Y561.461
G1 X156.978Y560.779
G1 X155.963Y560.142
G1 X154.917Y559.552
G1 X153.839Y559.012
G1 X152.731Y558.522
G1 X151.596Y558.083
G1 X150.434Y557.698
G1 X149.248Y557.369
G1 X148.038Y557.095
G1 X146.807Y556.88
G1 X145.556Y556.724
G1 X144.286Y556.63
G1 X143Y556.598
G1 X141.714Y556.63
G1 X140.444Y556.724
G1 X139.193Y556.88
G1 X137.962Y557.095
G1 X136.752Y557.369
G1 X135.566Y557.698
G1 X134.404Y558.083
G1 X133.269Y558.522
G1 X132.161Y559.012
G1 X131.083Y559.552
G1 X130.037Y560.142
G1 X129.022Y560.779
G1 X128.042Y561.461
G1 X127.098Y562.188
G1 X126.191Y562.957
G1 X125.322Y563.768
G1 X124.495Y564.618
G1 X123.709Y565.506
G1 X122.967Y566.431
G1 X122.27Y567.391
G1 X121.619Y568.384
G1 X121.017Y569.409
G1 X120.465Y570.464
G1 X119.965Y571.549
G1 X119.517Y572.66
G1 X119.124Y573.798
G1 X118.787Y574.959
G1 X118.508Y576.144
G1 X118.288Y577.349
G1 X118.129Y578.574
G1 X118.033Y579.818
G1 X118Y581.077
G1 X118.033Y582.337
G1 X118.129Y583.58
G1 X118.288Y584.805
G1 X118.508Y586.011
G1 X118.787Y587.195
G1 X119.124Y588.357
G1 X119.517Y589.494
G1 X119.965Y590.606
G1 X120.465Y591.69
G1 X121.017Y592.745
G1 X121.619Y593.771
G1 X122.27Y594.764
G1 X122.967Y595.723
G1 X123.709Y596.648
G1 X124.495Y597.536
G1 X125.322Y598.387
G1 X126.191Y599.197
G1 X127.098Y599.966
G1 X128.042Y600.693
G1 X129.022Y601.376
G1 X130.037Y602.012
G1 X131.083Y602.602
G1 X132.161Y603.142
G1 X133.269Y603.633
G1 X134.404Y604.071
G1 X135.566Y604.456
G1 X136.752Y604.786
G1 X137.962Y605.059
G1 X139.193Y605.274
G1 X140.444Y605.43
G1 X141.714Y605.524
G1 X143Y605.556
G1 X144.286Y605.524
G1 X145.556Y605.43
G1 X146.807Y605.274
G1 X148.038Y605.059
G1 X149.248Y604.786
G1 X150.434Y604.456
G1 X151.596Y604.071
G1 X152.731Y603.633
G1 X153.839Y603.142
G1 X154.917Y602.602
G1 X155.963Y602.012
G1 X156.978Y601.376
G1 X157.958Y600.693
G1 X158.902Y599.966
G1 X159.809Y599.197
G1 X160.678Y598.387
G1 X161.505Y597.536
G1 X162.291Y596.648
G1 X163.033Y595.723
G1 X163.73Y594.764
G1 X164.381Y593.771
G1 X164.983Y592.745
G1 X165.535Y591.69
G1 X166.035Y590.606
G1 X166.483Y589.494
G1 X166.876Y588.357
G1 X167.213Y587.195
G1 X167.492Y586.011
G1 X167.712Y584.805
G1 X167.871Y583.58
G1 X167.967Y582.337
G1 X168Y581.077
G0 X223Y582.077
G1 X222.967Y580.818
G1 X222.871Y579.574
G1 X222.712Y578.349
G1 X222.492Y577.144
G1 X222.213Y575.959
G1 X221.876Y574.798
G1 X221.483Y573.66
G1 X221.035Y572.549
G1 X220.535Y571.464
G1 X219.983Y570.409
G1 X219.381Y569.384
G1 X218.73Y568.391
G1 X218.033Y567.431
G1 X217.291Y566.506
G1 X216.505Y565.618
G1 X215.678Y564.768
G1 X214.809Y563.957
G1 X213.902Y563.188
G1 X212.958Y562.461
G1 X211.978Y561.779
G1 X210.963Y561.142
G1 X209.917Y560.552
G1 X208.839Y560.012
G1 X207.731Y559.522
G1 X206.596Y559.083
G1 X205.434Y558.698
G1 X204.248Y558.369
G1 X203.038Y558.095
G1 X201.807Y557.88
G1 X200.556Y557.724
G1 X199.286Y557.63
G1 X198Y557.598
G1 X196.714Y557.63
G1 X195.444Y557.724
G1 X194.193Y557.88
G1 X192.962Y558.095
G1 X191.752Y558.369
G1 X190.566Y558.698
G1 X189.404Y559.083
G1 X188.269Y559.522
G1 X187.161Y560.012
G1 X186.083Y560.552
G1 X185.037Y561.142
G1 X184.022Y561.779
G1 X183.042Y562.461
G1 X182.098Y563.188
G1 X181.191Y563.957
G1 X180.322Y564.768
G1 X179.495Y565.618
G1 X178.709Y566.506
G1 X177.967Y567.431
G1 X177.27Y568.391
G1 X176.619Y569.384
G1 X176.017Y570.409
G1 X175.465Y571.464
G1 X174.965Y572.549
G1 X174.517Y573.66
G1 X174.124Y574.798
G1 X173.787Y575.959
G1 X173.508Y577.144
G1 X173.288Y578.349
G1 X173.129Y579.574
G1 X173.033Y580.818
G1 X173Y582.077
G1 X173.033Y583.337
G1 X173.129Y584.58
G1 X173.288Y585.805
G1 X173.508Y587.011
G1 X173.787Y588.195
G1 X174.124Y589.357
G1 X174.517Y590.494
G1 X174.965Y591.606
G1 X175.465Y592.69
G1 X176.017Y593.745
G1 X176.619Y594.771
G1 X177.27Y595.764
G1 X177.967Y596.723
G1 X178.709Y597.648
G1 X179.495Y598.536
G1 X180.322Y599.387
G1 X181.191Y600.197
G1 X182.098Y600.966
G1 X183.042Y601.693
G1 X184.022Y602.376
G1 X185.037Y603.012
G1 X186.083Y603.602
G1 X187.161Y604.142
G1 X188.269Y604.633
G1 X189.404Y605.071
G1 X190.566Y605.456
G1 X191.752Y605.786
G1 X192.962Y606.059
G1 X194.193Y606.274
G1 X195.444Y606.43
G1 X196.714Y606.524
G1 X198Y606.556
G1 X199.286Y606.524
G1 X200.556Y606.43
G1 X201.807Y606.274
G1 X203.038Y606.059
G1 X204.248Y605.786
G1 X205.434Y605.456
G1 X206.596Y605.071
G1 X207.731Y604.633
G1 X208.839Y604.142
G1 X209.917Y603.602
G1 X210.963Y603.012
G1 X211.978Y602.376
G1 X212.958Y601.693
G1 X213.902Y600.966
G1 X214.809Y600.197
G1 X215.678Y599.387
G1 X216.505Y598.536
G1 X217.291Y597.648
G1 X218.033Y596.723
G1 X218.73Y595.764
G1 X219.381Y594.771
G1 X219.983Y593.745
G1 X220.535Y592.69
G1 X221.035Y591.606
G1 X221.483Y590.494
G1 X221.876Y589.357
G1 X222.213Y588.195
G1 X222.492Y587.011
G1 X222.712Y585.805
G1 X222.871Y584.58
G1 X222.967Y583.337
G1 X223Y582.077
G0 X284Y583.077
G1 X283.967Y581.818
G1 X283.871Y580.574
G1 X283.712Y579.349
G1 X283.492Y578.144
G1 X283.213Y576.959
G1 X282.876Y575.798
G1 X282.483Y574.66
G1 X282.035Y573.549
G1 X281.535Y572.464
G1 X280.983Y571.409
G1 X280.381Y570.384
G1 X279.73Y569.391
G1 X279.033Y568.431
G1 X278.291Y567.506
G1 X277.505Y566.618
G1 X276.678Y565.768
G1 X275.809Y564.957
G1 X274.902Y564.188
G1 X273.958Y563.461
G1 X272.978Y562.779
G1 X271.963Y562.142
G1 X270.917Y561.552
G1 X269.839Y561.012
G1 X268.731Y560.522
G1 X267.596Y560.083
G1 X266.434Y559.698
G1 X265.248Y559.369
G1 X264.038Y559.095
G1 X262.807Y558.88
G1 X261.556Y558.724
G1 X260.286Y558.63
G1 X259Y558.598
G1 X257.714Y558.63
G1 X256.444Y558.724
G1 X255.193Y558.88
G1 X253.962Y559.095
G1 X252.752Y559.369
G1 X251.566Y559.698
G1 X250.404Y560.083
G1 X249.269Y560.522
G1 X248.161Y561.012
G1 X247.083Y561.552
G1 X246.037Y562.142
G1 X245.022Y562.779
G1 X244.042Y563.461
G1 X243.098Y564.188
G1 X242.191Y564.957
G1 X241.322Y565.768
G1 X240.495Y566.618
G1 X239.709Y567.506
G1 X238.967Y568.431
G1 X238.27Y569.391
G1 X237.619Y570.384
G1 X237.017Y571.409
G1 X236.465Y572.464
G1 X235.965Y573.549
G1 X235.517Y574.66
G1 X235.124Y575.798
G1 X234.787Y576.959
G1 X234.508Y578.144
G1 X234.288Y579.349
G1 X234.129Y580.574
G1 X234.033Y581.818
G1 X234Y583.077
G1 X234.033Y584.337
G1 X234.129Y585.58
G1 X234.288Y586.805
G1 X234.508Y588.011
G1 X234.787Y589.195
G1 X235.124Y590.357
G1 X235.517Y591.494
G1 X235.965Y592.606
G1 X236.465Y593.69
G1 X237.017Y594.745
G1 X237.619Y595.771
G1 X238.27Y596.764
G1 X238.967Y597.723
G1 X239.709Y598.648
G1 X240.495Y599.536
G1 X241.322Y600.387
G1 X242.191Y601.197
G1 X243.098Y601.966
G1 X244.042Y602.693
G1 X245.022Y603.376
G1 X246.037Y604.012
G1 X247.083Y604.602
G1 X248.161Y605.142
G1 X249.269Y605.633
G1 X250.404Y606.071
G1 X251.566Y606.456
G1 X252.752Y606.786
G1 X253.962Y607.059
G1 X255.193Y607.274
G1 X256.444Y607.43
G1 X257.714Y607.524
G1 X259Y607.556
G1 X260.286Y607.524
G1 X261.556Y607.43
G1 X262.807Y607.274
G1 X264.038Y607.059
G1 X265.248Y606.786
G1 X266.434Y606.456
G1 X267.596Y606.071
G1 X268.731Y605.633
G1 X269.839Y605.142
G1 X270.917Y604.602
G1 X271.963Y604.012
G1 X272.978Y603.376
G1 X273.958Y602.693
G1 X274.902Y601.966
G1 X275.809Y601.197
G1 X276.678Y600.387
G1 X277.505Y599.536
G1 X278.291Y598.648
G1 X279.033Y597.723
G1 X279.73Y596.764
G1 X280.381Y595.771
G1 X280.983Y594.745
G1 X281.535Y593.69
G1 X282.035Y592.606
G1 X282.483Y591.494
G1 X282.876Y590.357
G1 X283.213Y589.195
G1 X283.492Y588.011
G1 X283.712Y586.805
G1 X283.871Y585.58
G1 X283.967Y584.337
G1 X284Y583.077
G0 X286Y625.116
G1 X236
G1 Y677.039
G1 X286
G1 Y625.116
G0 X227Y625.116
G1 X177
G1 Y677.039
G1 X227
G1 Y625.116
G0 X169Y624.116
G1 X119
G1 Y676.039
G1 X169
G1 Y624.116
G0 X110Y625.116
G1 X60
G1 Y677.039
G1 X110
G1 Y625.116
G0 X349.547Y625.479
G1 X299.547
G1 Y677.402
G1 X349.547
G1 Y625.479
G0 X409Y623.116
G1 X359
G1 Y675.039
G1 X409
G1 Y623.116
G0 X413Y577.077
G1 X412.967Y575.818
G1 X412.871Y574.574
G1 X412.712Y573.349
G1 X412.492Y572.144
G1 X412.213Y570.959
G1 X411.876Y569.798
G1 X411.483Y568.66
G1 X411.035Y567.549
G1 X410.535Y566.464
G1 X409.983Y565.409
G1 X409.381Y564.384
G1 X408.73Y563.391
G1 X408.033Y562.431
G1 X407.291Y561.506
G1 X406.505Y560.618
G1 X405.678Y559.768
G1 X404.809Y558.957
G1 X403.902Y558.188
G1 X402.958Y557.461
G1 X401.978Y556.779
G1 X400.963Y556.142
G1 X399.917Y555.552
G1 X398.839Y555.012
G1 X397.731Y554.522
G1 X396.596Y554.083
G1 X395.434Y553.698
G1 X394.248Y553.369
G1 X393.038Y553.095
G1 X391.807Y552.88
G1 X390.556Y552.724
G1 X389.286Y552.63
G1 X388Y552.598
G1 X386.714Y552.63
G1 X385.444Y552.724
G1 X384.193Y552.88
G1 X382.962Y553.095
G1 X381.752Y553.369
G1 X380.566Y553.698
G1 X379.404Y554.083
G1 X378.269Y554.522
G1 X377.161Y555.012
G1 X376.083Y555.552
G1 X375.037Y556.142
G1 X374.022Y556.779
G1 X373.042Y557.461
G1 X372.098Y558.188
G1 X371.191Y558.957
G1 X370.322Y559.768
G1 X369.495Y560.618
G1 X368.709Y561.506
G1 X367.967Y562.431
G1 X367.27Y563.391
G1 X366.619Y564.384
G1 X366.017Y565.409
G1 X365.465Y566.464
G1 X364.965Y567.549
G1 X364.517Y568.66
G1 X364.124Y569.798
G1 X363.787Y570.959
G1 X363.508Y572.144
G1 X363.288Y573.349
G1 X363.129Y574.574
G1 X363.033Y575.818
G1 X363Y577.077
G1 X363.033Y578.337
G1 X363.129Y579.58
G1 X363.288Y580.805
G1 X363.508Y582.011
G1 X363.787Y583.195
G1 X364.124Y584.357
G1 X364.517Y585.494
G1 X364.965Y586.606
G1 X365.465Y587.69
G1 X366.017Y588.745
G1 X366.619Y589.771
G1 X367.27Y590.764
G1 X367.967Y591.723
G1 X368.709Y592.648
G1 X369.495Y593.536
G1 X370.322Y594.387
G1 X371.191Y595.197
G1 X372.098Y595.966
G1 X373.042Y596.693
G1 X374.022Y597.376
G1 X375.037Y598.012
G1 X376.083Y598.602
G1 X377.161Y599.142
G1 X378.269Y599.633
G1 X379.404Y600.071
G1 X380.566Y600.456
G1 X381.752Y600.786
G1 X382.962Y601.059
G1 X384.193Y601.274
G1 X385.444Y601.43
G1 X386.714Y601.524
G1 X388Y601.556
G1 X389.286Y601.524
G1 X390.556Y601.43
G1 X391.807Y601.274
G1 X393.038Y601.059
G1 X394.248Y600.786
G1 X395.434Y600.456
G1 X396.596Y600.071
G1 X397.731Y599.633
G1 X398.839Y599.142
G1 X399.917Y598.602
G1 X400.963Y598.012
G1 X401.978Y597.376
G1 X402.958Y596.693
G1 X403.902Y595.966
G1 X404.809Y595.197
G1 X405.678Y594.387
G1 X406.505Y593.536
G1 X407.291Y592.648
G1 X408.033Y591.723
G1 X408.73Y590.764
G1 X409.381Y589.771
G1 X409.983Y588.745
G1 X410.535Y587.69
G1 X411.035Y586.606
G1 X411.483Y585.494
G1 X411.876Y584.357
G1 X412.213Y583.195
G1 X412.492Y582.011
G1 X412.712Y580.805
G1 X412.871Y579.58
G1 X412.967Y578.337
G1 X413Y577.077
G0 X351Y583.077
G1 X350.967Y581.818
G1 X350.871Y580.574
G1 X350.712Y579.349
G1 X350.492Y578.144
G1 X350.213Y576.959
G1 X349.876Y575.798
G1 X349.483Y574.66
G1 X349.035Y573.549
G1 X348.535Y572.464
G1 X347.983Y571.409
G1 X347.381Y570.384
G1 X346.73Y569.391
G1 X346.033Y568.431
G1 X345.291Y567.506
G1 X344.505Y566.618
G1 X343.678Y565.768
G1 X342.809Y564.957
G1 X341.902Y564.188
G1 X340.958Y563.461
G1 X339.978Y562.779
G1 X338.963Y562.142
G1 X337.917Y561.552
G1 X336.839Y561.012
G1 X335.731Y560.522
G1 X334.596Y560.083
G1 X333.434Y559.698
G1 X332.248Y559.369
G1 X331.038Y559.095
G1 X329.807Y558.88
G1 X328.556Y558.724
G1 X327.286Y558.63
G1 X326Y558.598
G1 X324.714Y558.63
G1 X323.444Y558.724
G1 X322.193Y558.88
G1 X320.962Y559.095
G1 X319.752Y559.369
G1 X318.566Y559.698
G1 X317.404Y560.083
G1 X316.269Y560.522
G1 X315.161Y561.012
G1 X314.083Y561.552
G1 X313.037Y562.142
G1 X312.022Y562.779
G1 X311.042Y563.461
G1 X310.098Y564.188
G1 X309.191Y564.957
G1 X308.322Y565.768
G1 X307.495Y566.618
G1 X306.709Y567.506
G1 X305.967Y568.431
G1 X305.27Y569.391
G1 X304.619Y570.384
G1 X304.017Y571.409
G1 X303.465Y572.464
G1 X302.965Y573.549
G1 X302.517Y574.66
G1 X302.124Y575.798
G1 X301.787Y576.959
G1 X301.508Y578.144
G1 X301.288Y579.349
G1 X301.129Y580.574
G1 X301.033Y581.818
G1 X301Y583.077
G1 X301.033Y584.337
G1 X301.129Y585.58
G1 X301.288Y586.805
G1 X301.508Y588.011
G1 X301.787Y589.195
G1 X302.124Y590.357
G1 X302.517Y591.494
G1 X302.965Y592.606
G1 X303.465Y593.69
G1 X304.017Y594.745
G1 X304.619Y595.771
G1 X305.27Y596.764
G1 X305.967Y597.723
G1 X306.709Y598.648
G1 X307.495Y599.536
G1 X308.322Y600.387
G1 X309.191Y601.197
G1 X310.098Y601.966
G1 X311.042Y602.693
G1 X312.022Y603.376
G1 X313.037Y604.012
G1 X314.083Y604.602
G1 X315.161Y605.142
G1 X316.269Y605.633
G1 X317.404Y606.071
G1 X318.566Y606.456
G1 X319.752Y606.786
G1 X320.962Y607.059
G1 X322.193Y607.274
G1 X323.444Y607.43
G1 X324.714Y607.524
G1 X326Y607.556
G1 X327.286Y607.524
G1 X328.556Y607.43
G1 X329.807Y607.274
G1 X331.038Y607.059
G1 X332.248Y606.786
G1 X333.434Y606.456
G1 X334.596Y606.071
G1 X335.731Y605.633
G1 X336.839Y605.142
G1 X337.917Y604.602
G1 X338.963Y604.012
G1 X339.978Y603.376
G1 X340.958Y602.693
G1 X341.902Y601.966
G1 X342.809Y601.197
G1 X343.678Y600.387
G1 X344.505Y599.536
G1 X345.291Y598.648
G1 X346.033Y597.723
G1 X346.73Y596.764
G1 X347.381Y595.771
G1 X347.983Y594.745
G1 X348.535Y593.69
G1 X349.035Y592.606
G1 X349.483Y591.494
G1 X349.876Y590.357
G1 X350.213Y589.195
G1 X350.492Y588.011
G1 X350.712Y586.805
G1 X350.871Y585.58
G1 X350.967Y584.337
G1 X351Y583.077
M9
G1 S0
M5
G90
G0 X0Y0
M2
Stream completed in 2:39
Thank you! i will go through this guide step by step and see if it fixes it. I will be working on this over the next couple of days and will report back.
SOLVED:
Alright, thank you once again EVERYONE who helped me with this issue. I went through the entire guide to mechanical adjustments and maintenance. Double checked everything. Guide was absolutely amazing.
That being said, after following the guide perfectly, i started up my laser, and 2 minutes into a project SAME THING HAPPENED.
Now, while during this issue, i contacted Sculpfun customer service, and they pointed me in a direction i never would have imagined.
Solution for anyone having same issue:
When i purchased this Sculpfun laser, the selling told me he installed an expansion kit onto the sculpfun s30, making it 900mm x 900mm. What he failed to tell me, was that the laser started having issues once he installed the expansion kit (That was kind of fellow craigslist guy :rofl:)
When installing an expansion kit on the Sculpfun S30, it is required that you increase the voltage of the x and y axis motors inside of the controller via potentiometers.
Previous owner appeared to have tried to do so, but instead of turning the voltage potentiometer screw to the right position, the screw position was off by like… a very thin hair. After making sure both potentiometers were set correctly, so far fingers crossed the laser has worked without funky results SO FAR.
My take is that since the potentiometer screw was slightly off, a very small lower voltage went to the X axis motor, which over time made the motor bog down and not keep up with the Y axis motor. Therefor, after a bit it would completely bug out.
anyways, hope this helps someone else having the same issue as i did, and hope between the previous responses, and my info you can fix your issue as well!
Happy burning folks.
Aha! The extended rails needed a higher stepper motor current.. That checks out.
Thank you for sharing the solution!
A small thing to add here: Sculpfun recommended turning the poti 90 degrees, which causes a lot of issues for many users. Turning it by 45 degrees only is much better. They also tell this now, but they didn’t change any of the initial guides.. :slight_smile:
How many volts of Vref is 45 degrees on the potentiometer? :melting_face:
I would prefer to know the correct voltage to adjust it with a multimeter.
@OakfireReserve, I recommend Melvin’s other excellent guide about the extensions to double-check your Device Settings, Firmware Settings, and the reference voltage:
Bravo! Most excellent write-up about your resolution.
Thank you! thank you! Thank you! Thank you!
Also glad to know you came to a successful resolution, but THANK YOU for your forum form.
Roughly about 1.15V.
