Trying to resize slots in a shape
Im trying to widen the slot to 3.7mm from 3.12mm, but the toolwont recognize the slot :slight_smile:
Been looking around on the forum to try and find the answer but im lost…
The “inner” corners are 90degrees, the “outer” corners are not 90degrees since its done in a circle. I´m total noob at this but trying to get wifey happy with a new lamp screen :smiley:
LampaOrg65leaf.lbrn2 (12.7 KB)
There is an extra note hidden under the green note in the top left corner, removed it and all is well.
Adding onto what Bernd said, if you find this is happening on other shapes, you may want to try using the Offset tool with an Offset Distance of 0 and Optimize Results enabled to clean up the shape. Turning on Delete original objects is a good idea as well, so you don’t end up with duplicated shapes.
2024-04-02_14-20-36
Super thanks for the fast help :slight_smile:
