after the last update tumblers now are mirror and it moves the start point off scale i’m not the only one having this problem if you are in our facebook page yoraHome cnc users group you can see otheres, so if no fix now is there a way to roll back the update???
Do you have the “mirror output” toggle enabled on the Rotary Setup screen?
No mirror output is off. I removed 1.0.0.4 and install 1.0.0.3 and still the same but i did use a save file so will try a new one and see will be tommarow after work befor i can try again.
