I’m trying to automate the cut process with a python script and tried to change the cut-parameter in prefs.ini before starting LightBurn and converting an svg to rd.
The config is easily parsable (thank you!), but for every name (e.g. “C00”) there are two entries in the “CutList” which suprised me. Which one is used? And what is the use of the other set of parameters?
I would also like to thank for the open design of Lightburn. The most important functions have hot-keys and the config as well as lbrn(2) are human readable!
P.S: is it “cut” vs “Image” in “type”?
