Trying to upgrade from LB 0806 to 0902…keep getting a access denied message and cant delete
am i missing something?
This should do the trick
thanks but this is in windows 7 …
Make sure it isn’t running in the background, possibly? Press Ctrl+Shift+Esc and look for LightBurn in the task manager. If it’s running already you wouldn’t be able to replace it.
When you say “can’t delete”, which file can’t you delete?
It will be the same process in windows 7. Did you even try it? I have had to do this many times in Win 7.
Here it is straight from the horses mouth. Be sure to scroll down to the section for Windows 7.
