UI suggestions - Improvements to workflows
  1. Add a ctrl or alt to the cut tool that will cause it to cut any line it passes over without the required click to confirm. This would speed up repetitive cuts that pass beyond a shape or line and save on button clicks.
  2. Add a setting that filters the Cuts/Layers to only those that are active or used on a specific page.
  3. Add 2 categories to this website: UI Suggestions and Bugs.
Just a small comment on your point 3.
Up on the page here you will find a section that should/can be used for suggestions.
Errors and deficiencies can be sent directly from inside LB, including documentation, or in the respective sections here, in the forum.
to point 2, you have always had the option to sort and hide and deactivate individual layers, bar with a small check mark. (if that’s what you mean)
Sure, I use the show and output toggles on the cuts/Layers all the time. What I’m talking about is a filter that only displays the layers in the Cuts/Layers window that are being used by the page. So if you have 15-20 layers, but Page 2 only uses layer 2, then when you click on page 2, the Cuts/Layers window only displays layer 2. If you add an object to say layer 5, then you will see layer 2 and layer 5 in the window.
I understand what you mean with this. You are saying to show only 1 or 2 lines in the Cuts/Layers window instead of 5 or 10 of them.
The Pages thing is a very new feature. Add this idea to Fider and get it voted on.
Cut Shapes does that in a single operation for all lines extending beyond a closed shape:
Stipulated: Without a closed shape or when you want only a few lines cut, it’s the wrong hammer.
