Hi there,
I made a mistake when wiring the ultimate air assist system. The switch and the air solinoid valve were wired correctly, but the the wires going to the base of the relay (A1 and A2 as on the cloud ray wiring sheet) were reversed.
Now that they are in the correct position the following is happening:
When in auto mode the air solinoid will click on and off as per layer requirements, however the relay will not click on and activate the air pump.
When I switch over to full manual on the switch, the relay activates powering on the air pump and opening the air solinoid valve as expected - to be always on. However, when I switch back to auto mode on the toggle switch, the relay / air pump stay on and the air solinoid valve closes.
I am wondering if by incorrectlying wiring initally, have I damaged the relay or other parts of the system?
I am currently testing this with the laser tube off (just incase this makes a difference as I wish to get it working correctly, so I dont cause damage to the laser components).
I am new to Co2 having upgraded from a ortur master 2. The ruida controller is 6445G and is running firmware version 15.01.19.
