Hi, I have had to reinstall my lightburn after a pc update, when now doing text the blue circle has disappeared so I can’t bend the text - any ideas?
Try if you can bend the text in my little file.Text-test.lbrn2 (23.8 KB)
Thx, but weirdly lightburn doesn’t recognise that as a file it can open?
I think bending text came out in version 0.9.12
I have the same older version as before and it worked then but not when reinstalled - anyway paid £23 to update and is there now again - thx anyway
… a lot has happened since then !!!
The file format is e.g. extended / changed to .lbrn2, that’s probably why you can not load my small file.
the current version is:
I want to think that there was simply a mixup in versions but find this slightly worrisome if true.
I didn’t think LightBurn employed any server-side feature enablement so this would come as a surprise. Although not sure if this is how dsp/g-code functionality is handled.
Maybe we can get some insight from @LightBurn after the holiday.
GCode / DSP is handled by the license, but individual features are not, and none of the features are date stamped like that. I believe this had to have been a version mixup.
