Unable to Dock visible Shape
I can reduce my problem to simple test case
  1. Create a array of small squares on layer 2 filling most of work area.
  2. Set Layer 2 to not “output” and not “show”
  3. Create rectangle in center of layer 1
  4. Try to dock rectangle to left border layer 1
  5. Rectangle docks to nearest object in Layer 2 even though layer 2 is not visible
Reality configuration
All layers are set to not “output” and not “show” except Layer 00
Trying to Dock two shapes together on the 00 layer.
Instead of docking to closest object on the 00 layer it docks to closest object on any layer even though object may or may not be visible.
Is this by design?
Is it by configuration?
Is there a work around other than using separate instance of LightBurn with only one layer ?
