Unable to Frame My Project in Falcon 2 40watt
Hi I am unable to frame a project with the Creality Falcon 2 40watt. It homes correctly, moves the correct distances when moved but when I want to frame my project which is only 100mm x 100mm it goes the full width of the X axis about 400mm and stops at the limit switch. I have the machine settings etc all set up in device settings.
Can anyone help as I have only just received it today and trying to test the laser settings.
Also even though I set the finish position of the engrave as the Origin it wants to keep going off on the Y axis 300mm to the back and onto the x limit switch. The origin I have is X20mm and Y125mm.
Lightburn doesn’t seem to know the device setup for some reason
Thanks
Please post your machine settings here by opening the console window and typing $$. Copy and paste the results.
Thanks for trying to help, see below for my settings.
[OK]system start-up CV50-MASTER-Release V3.0.1 20230511-1116
re_info->power:40W ,CV50-LASER-40W-Debug V3.0.1 20230718-0952
usb connect succeed
ok
[OPT:VH]
[software versions: CV50-MASTER-Release V3.0.1 20230511-1116]
ok
Homing
ok
$0=10
$1=250
$2=0
$3=4
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=2000.000
$25=4000.000
$26=20
$27=2.000
$30=1000.000
$31=0.000
$32=1
$100=80.000
$101=80.000
$110=25000.000
$111=8000.000
$120=500.000
$121=500.000
$130=400.000
$131=415.000
$150=1
$151=4
$152=30
$153=0
$154=0
$155=0
$156=0
$157=1
$158=1
$160=1
$161=8.00
ok
