can’t restore default from machine
It’s generally a really bad idea to do a factory settings reset - it resets to the settings that default for the board, which are completely generic and will know nothing about the machine it was installed in.
If you used LightBurn to change the settings, you can go to File > Open prefs folder, look in the backups for a copy of the machine settings from before they were changed.
Copy the file out and load them in Edit > Machine Settings, then click Write.
Thanks for the advise . Alsdo having problems with rotary attachment logos shrinking in size
