Unable to set the z axis
Emblaser 2
LightBurn pro
IMac 2025
no material inputs on cut/layers unable to set the z axis for cuts- laser diode does jog.
worked fine on previous version ?
Could it be that the “Z control” is simply disabled?
Please confirm if it is enabled. In version 2.0 the appearance changes but the location remains the same.
Hi Kurth, yes running version 2.0.04
Yes, you have Z control enabled?
Sorry, i don’t fully understood…
previous version you set the material heights in mm as an offset which adjusted the z axis. Now unable to set or move the diode ? Now i don’t know if its software or hardware
Yes z axis enabled
I have no knowledge of the machine or operating system you are working with.
The suggestion that occurred to me is that the option might be disabled.
If that’s not the case, I suggest you wait for other opinions.
I apologize for my lack of help.
thx for responding
Have you tried importing the .lbprefs file dated from before the upgrade?
