Unblur an image for burning
One of my friends just lost her 19 year old son to cancer. She has a favorite picture of him I am trying to burn with nothing close to success and unfortunately this is the original copy of the photo. Can anyone recommend the settings I should use to improve the clarity/ quality of the burn? sculpfun s30 pro max 22w
Not really what you where asking - but I upscaled the image to 1722x3000 and used Affinity Photo to clean things up a bit.
When you now import this into LB it will be huge, so you need to resize – this will have the result of having far more detail than before.
The other “issue” is that the color palette is so “white” - so all the dithering will make things kind of look the same and hence even more blurr. Greyscale probably will work best though.
To try and help with that - some light recolouring - hat and t-shirt. Now they are different to the face, it should be more distinct when you engrave.
– Sorry for your friends loss.
Gx
Sorry for your friend’s loss. Wishing them comfort.
I began with Glenn’s image, thank you @GPG342 and made adjustments in LightBurn.
This version was created using LightBurn 2.0.00-RC-7, a five-watt diode, on MDF.
Your settings may/will vary, but I recommend starting with low power and a steady speed—just not too slow to prevent fire risk.
File attached for reference.
Photo Test.lbrn2 (189.2 KB)
HTH.
that is amazing, thank you!
thank you so much! I’ll post my results if I have success
Your welcome - fingers crossed the outcome is usable for your friend.
G
I really cannot thank you enough. I think it turned out pretty nice. I will be giving it to her this weekend
Turned out nice - good contrast in the etch.
Am sure she love it.
G
