Hi,
I have just updated LightBurn to 0.9.12 and have run into an issue where I am getting unexpected starting positions when I start a job.
I have saved the Code for each of the ‘Start From’ options and what I have found is:
Current Position: runs as expected
User Origin: adds ‘G0 X-234 Y-148’ as the first move, this causes the machine to hit the limit switches.
Absolute Coords: moves to the expected start position but then adds ‘G0Z10000’.
This did not occur before the update. I have tried to find any reference to these moves in preferences and settings to no avail. When I check the ‘$#’ on my machine, the values are correct and to not contain any of the strange moves coords.
I have not updated my GRBL controller so I have either made a mistake in the past that the new LightBurn version is now highlighting or I have missed a setting in the new version.
Any help would be greatly appreciated.
Cheers,
Mal
P.S. I’m a new user on the forum so I can’t post file yet.
The Z change is something that was supposed to fix an issue for Emblaser devices, but appears to have side effects. I’m guessing you have ‘Relative Z moves’ and Z enabled - can you confirm?
The user origin thing is weird - no recent changes should have affected that, so I’m not sure what’s happening there. Can you type $# in the console and press enter, and post the output?
That G54 offset at the beginning might have something to do with the user origin issue. What is your $10 setting? (I’m assuming this is GRBL - do you have homing on this machine?)
I have my machine homing to the top/right of the bed and then set an offset to the bottom/left so the machine works in positive values from that point. I’m not sure exactly why I set it up that way, probably seemed like a good idea at the time. lol
I can change it so it homes to the bottom/left and see what that does.
disregard that, I did a reset and now it works fine except for the z axis thing. If I disable the relative z axis it works as expected so I think I am good. I’m not sure If I will need to change anything else.
I will give it a go on a few jobs over the next few days and let you know how it goes.
