Unlinking a color to setting
OK, somehow a color has linked to a setting. When I open LB create a shape and use that color it comes up 'LINKED" would not be an issue but it is not a setting for that color I use. I can manually unlink it and set to the proper settings, but it is a pain :frowning: I’m lazy. Can not find where to permanently UNLINK the color. help…
Linking is a Library operation. Somewhere, when you were editing your Library and Cut/Layers, you linked that layer to one of your Library entries. Open your library tab and find out which setting has been linked.
Select the Layer and under the cuts/layers window it shows the link from your library and it should also show an Unlink button. Press that and you’re done.
You may need to save your Library after unlinking.
Thanks, Had to manual unlink then save library. Then set to style and power and save as default. But got it. Have a Happy Thanksgiving :slight_smile:
