Hello, having trouble figuring out how to unstack a mandala file by layer. When downloaded it is 4 layers stacked. If I ungroup it then every tiny cut is separate, so I am unable to move them away from each other as a layer. I appreciate any help to get the layers grouped individually so they can be cut separately. thank you!!!
You can hold the ‘Shift’ key while clicking a layer color in the ‘Cuts / Layers’ window to select every shape on that layer, which is also in the menu under ‘Edit’→’Select all shapes in current layer’. Once selected, you can then ‘Group’ those shapes and move as desired.
Well Rick you absolutely made my day, thank you bunches!!!
Thanks for he reply Rick, I have been holding the shift key and that can get a bit sore with pressure on the finger, much better idea…
