Hello. I turned my laser 90 degree counter clockwise yesterday on my work area now I can’t get my stored to match up and I can’t figure out how to swap my x/y axis is someone could please help. When I tried to invert them in the settings then my homing was off.
If you rotate the machine 90 degrees, the Home switches and coordinate system rotates with it. You cannot tell it the limit switches are in a new place. If the machine worked before you rotated it, it should work after you rotate it too.
Idk but when I rotated it, my controls are different now but I didn’t change anything. I literally just turned it. My side arrows are ok but my up and down are reversed
Generally, this isn’t so easy as the machine orientation is relative to the controller, not you, so generally you can’t just rotate a machine and make a software change to fix this. It involves the controller also.
There is an option for swapping X and Y axes… might try that, I’ve never used it.
Good luck
I tried that and it didn’t work. I just rotated my laser back to where it was lol. But now my CO2 is doing it. It hooked in the right corner and moves correctly until I hit start then it starts in an opposite corner but I just set it up so I need to see if image is reversed and everything.
Sounds like you have them incorrectly configured. What did you change? Did you change it back?
Yes I just changed it back to where I had it bc no matter what I did. Reverse one didn’t work both didn’t work. Went into settings and looked at older post and changed a few things I just couldn’t get it to work right so I rearranged my room which it needed done and turned my machine back around but I would eventually like to know how to do that stuff I’m sure it will be needed at some point. But right now I can’t get lightburn to work it keeps crashing and disconnecting on me today.
My CO2 though. It homes correctly and moves correctly with the arrows but when I hit start… It starts on the opposite corner of the previous. If it shows the right then it starts on the left.
Preview not previous
