just updated to .05 and fill doesn’t work, have I changed a setting? can I go back to .04?
Yes, you can easily, find the version you want to go back to and install it - without first uninstalling the old version.
In what way does it not work? If you’re basing this on the shapes not appearing filled on-screen, then make sure that you’re using a filled View style in Window menu. If not, switch to one of those.
Thanks, the filled smooth was not checked.
