Has anyone had trouble with new lightburn update? i run update last night now when i engrave it jumps around on the job nomatter if i use fill groups,individually or what. version 1.0.06.it did not do this untill after updat
Do you have Flood Fill enabled? Which version were you using before?
not sure what version i was using before,i had someone helping me last night with issues and they said i needed to uninstall and after i downloaded and got going again,im having this issue.Where is flood fill i can not seem to find it
yes it is i just found it,do i need to un check?
It is the reason your fill is jumping all over. If you don’t want it to do that, then uncheck Flood Fill.
https://lightburnsoftware.github.io/NewDocs/CutSettings-Fill.html#flood-fill
i have unchecked it but it still does same thing
Can you attach the file that you’re trying to run here?
2 posts were split to a new topic: C3D board startup issues
