Updated now I have an error
After updating to the latest version I get the following error every time I try to use Lightburn. What changed?
Waiting for connection…
ok
[VER:1.1h.2022070601:]
[OPT:VZ,15,128]
Target buffer size found
ok
ok
[OPT:VZ,15,128]
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
ok
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
This is almost certainly unrelated to the upgrade.
Please provide the following:
  1. When do you get this error?
  2. Is your machine homing properly?
  3. Are you using Absolute Coords as your Start From mode in Laser window? If not, I suggest you try that.
I get the error in every thing I try to burn or frame.
My machine is set for machine position.
This is what I used for the last year with no problem until I did the update.
Can you take a full screenshot of LightBurn with the design loaded and Laser window showing?
